Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hunter System 700 tire balancer
  #30 (permalink)
Old 10-21-2009, 11:17 AM
Oldswrench Oldswrench is offline
Hunter 700 cal
Thanks oldcpecdr. I appreciate it very much. Have been going through the manual and trying to perform the Pre-Calibration Check, it says to place the Static/Dynamic switch in the Override position. This machine has Dynamic, Static, and Test. I assume that test is the override position, but I am not sure as it only reads on the upper display and we are looking for both upper and lower to read zero! So I tried again in Dynamic and in fact both upper and lower read zero. Then on to the Calibration itself, and I do not have the 278 gram calibration weight (P/N 65-27-2). Is this something that is still available or am I reaching to far back for this perticular piece of equiptment?
Thanks again
