Hunter System 700 tire balancer - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-15-2009, 06:35 PM
Hunter 700 balancer
Originally Posted by oldcpecdr
Send me an email adress and I will send you the service manual in PDF form
I also would like intuction manuel if you still have this was off older post sometime back,thanks mike Mhenry@elmore.rr.com
  #17 (permalink)
Old 03-16-2009, 06:57 AM
Lot of Old 700's
Must be lot's of old 700 Balancers out there, Manuals sent...GL
  #18 (permalink)
Old 04-28-2009, 10:30 AM
Hunter System 700
Hi went to fire up our balancer this morning and it's not working. .. I would really appreciate a copy of the manuals and calibration instructions.... Thank You very much in advance
Mark...
markw10@netzero.net
  #19 (permalink)
Old 04-28-2009, 01:17 PM
hunter system 700
If any of the manuals or repair specs are still available
edgyboy , a new member who just registered less than an hour ago , still has his fingers crossed. Please forward a copy to edwanders@aol.com
Thanking all of you who choose to respond. :
  #20 (permalink)
Old 04-30-2009, 10:07 PM
another hunter 700
Any info out there on the automatic stop(reverse polarity)on the 700 series.Mine works only when the stop button is pushed and held.Also requires the stop button or it will spin all day.I kinda figured both problems are related.The caliberation specs would be a great help too.reply to jennandteddie@aol.com . Thanks Ted
  #21 (permalink)
Old 06-10-2009, 03:53 PM
Huter System 700 pdf
elektro_inyenyry@yahoo.es
  #22 (permalink)
Old 06-10-2009, 04:37 PM
700 sent
sent ...good luck,
Mike B
  #23 (permalink)
Old 06-26-2009, 08:31 AM
i need the manual or the procedure to calibrate my hunter 700...someone can help me...?
  #24 (permalink)
Old 06-26-2009, 09:24 AM
Hunter 700
Send me your email address and I will fix you up...
oldcpecdr@aol.com
Mike B
  #25 (permalink)
Old 06-26-2009, 05:56 PM
burnpalm@hotmail.com
thank you
  #26 (permalink)
Old 08-04-2009, 05:28 PM
Need Help Calabrating Hunter 700 Wheel Balancer
Hello
I Have A Hunter 700 Wheel Balancer 3 Phaze.
Can Someone Send Me Service Manual And Owner Manuals?
Thanks Dave
davidlockridge@insightbb.com
  #27 (permalink)
Old 08-04-2009, 08:56 PM
sent
Sent, GL
Mike B
  #28 (permalink)
Old 10-21-2009, 08:05 AM
Hunter 700
Hi new to the forum, but I would also like a calibration manual/instructions to calibrate a 700 hunter wheel balencer. Please send to
gso@artmaintenance.com
or
mlovely@triad.rr.com
Thanks in advance for your help.
Mark
  #29 (permalink)
Old 10-21-2009, 08:45 AM
Good Luck
File Sent, good luck with that old beast.. Mike
  #30 (permalink)
Old 10-21-2009, 11:17 AM
Hunter 700 cal
Thanks oldcpecdr. I appreciate it very much. Have been going through the manual and trying to perform the Pre-Calibration Check, it says to place the Static/Dynamic switch in the Override position. This machine has Dynamic, Static, and Test. I assume that test is the override position, but I am not sure as it only reads on the upper display and we are looking for both upper and lower to read zero! So I tried again in Dynamic and in fact both upper and lower read zero. Then on to the Calibration itself, and I do not have the 278 gram calibration weight (P/N 65-27-2). Is this something that is still available or am I reaching to far back for this perticular piece of equiptment?
Thanks again
Mark
Canadian Tire wrecks engine 4 Jaw Chuck Hotrodders' Lounge 31 12-09-2010 10:39 PM
I Think Someone Doesn't Like Me. (3rd tire problem) Ghetto Jet Hotrodders' Lounge 12 05-22-2009 05:15 AM
Not a hot rod tire question but it could be old-bill-t Suspension - Brakes - Steering 13 03-04-2008 09:29 PM
tire pressure monitoring system question!! hemi43 Suspension - Brakes - Steering 4 05-07-2007 06:56 AM
How to determine effective tire diameter sabino56 Transmission - Rearend 19 10-27-2006 09:19 PM
