hurst line lock - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2008, 07:44 PM
hurst line lock
OK, here's a question i'll be suprized if somebody answers. i have the old style hurst line lock, it is supposed to be rebuildable. it has the solinoid in the center and a body on each side where the brake lines go in and out. each end peice had a flat on it for turning, i figured they were threaded into the center. each end turns easily and independently--they don't screw out, there are no snap/retaining rings visible. any body ever taken one of these things apart??? i want to rebuild/glass bead/repaint it. how does this darn thing come apart???
i checked the hurst web sight and it is totally useless...
Old 02-14-2008, 08:22 PM
Do you have a model number?
Shane
Old 02-14-2008, 08:44 PM
well now that you ask i just went out and looked an could see nothing so i hit it with the wire brush in one of my bench grinders ti bust the surface rust off. it says:
12 VOLT
WHEEL CYL
S/NO 1328
(I THINK THE LAST # IS AN 8, COULD BE A 3 BUT IT LOOKS LIKE 8)
even if i could find an exploded view i could figure out how it comes apart.
Old 02-14-2008, 08:46 PM
life is a temporary assignment
Can you post a pic?
Old 02-14-2008, 09:09 PM
Originally Posted by NEW INTERIORS
Can you post a pic?
i can try to tomorrow, i'm not too good at pic posting but i'll give it a try.
Old 02-15-2008, 01:46 PM
streetrodderbn's Avatar
Certifiable Streetrodder
the early line lock was not rebuildable, it is identified by the center case having a crimped edge on each end, the flats are to hold the line lock from turning while you tighten the brake line,not to unscrew the line lock assembly. yours is most likely this model. I have a rebuildable unit on my roadster, it is not a steel solenoid casing, but aluminum, and has a snap ring securing the end that unscrews. hope this helps!
efi fuel line sizing / fuel pump Blob Engine 2 09-25-2005 12:25 PM
leaky fuel line? jackflash Engine 1 08-15-2005 03:16 PM
brake line update 61bone Suspension - Brakes - Steering 5 07-07-2005 04:42 AM
brake line lock as security measure? blndweasel Suspension - Brakes - Steering 4 04-05-2005 06:33 PM
What exactly is a line lock? frankenvette Transmission - Rearend 39 03-16-2005 06:03 AM
