hurst shifter, saginaw 4speed shifting problems - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-03-2014, 08:13 PM
Originally Posted by latimermichael88 View Post
ok so heres where in at. i pulled the shifter, drilled and tapped the holes for the stop bolts theraded the bolts in, bolted the shifter back in hooked up the linkages correctly. got in the truck, ran it through the gears and it was smooth like butter. then i start the truck run it through the gears and i have the same problem as before cant get 1st without going to 2nd and so on.
I am going to suggest this for the second time and then mind my own business. If it shifts properly until you start the engine, it is probably not a transmission problem but a dragging clutch issue. Make sure your clutch is properly adjusted or not worn out.
If I am miss-understanding what you are trying to say, I apologize.
John
The Following User Says Thank You to John long For This Useful Post:
latimermichael88 (02-03-2014)
  #17 (permalink)
Old 02-03-2014, 08:22 PM
thanx
thanks john ill jack it up in the morning and pull the trans out and see whats going on with the clutch. i just wanted to eliminate the shifter before i pulled the trans back out.
  #18 (permalink)
Old 02-03-2014, 08:30 PM
Before you pull the trans just try to adjust the clutch so it releases well above the floor. A worn out clutch will run out of free travel at the top and still drag at the bottom but if it is just out of adjustment you will have too much free travel at the top and it will release too close to the floor.
If it is a hydraulic clutch that opens up another can of worms.
John
  #19 (permalink)
Old 02-03-2014, 08:38 PM
when i had the trans out before i noticed the input shaft had worn spots from where the clutch plate had been working on it. kinda like it had been flopping around or something
  #20 (permalink)
Old 02-03-2014, 08:52 PM
RAYFIN's Avatar
Last journal entry: before picture
Another idea is maybe someone put the wrong linkage on it. I used to run a vertical gate/ muncie 4 spd with stock chevy linkage and had nothing but problems. Went out of adjustment a lot, stuck between gears etc. Vertical gate had straight linkage, mine was twisty like factory cheby.
  #21 (permalink)
Old 02-03-2014, 10:01 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
That reminds me I worked on a G2 Camaro with a Saginaw 4 speed with a Hurst shifter and adapter plate and someone used one of the Saginaw rods and arm and it kept getting stuck in gear LOL It took forever to figure it out!!!
Jester
  #22 (permalink)
im sure the linkage is correct. ive checked it a bunch now
hurst, saginaw, shifter, transmission
Problems w/new shifter (4-spd Hurst) DaveWms Transmission - Rearend 3 05-30-2013 09:30 AM
Saginaw 4speed overdrive Ed Voss Transmission - Rearend 1 08-30-2011 07:23 PM
Saginaw 4speed Question razdude Transmission - Rearend 6 11-07-2006 05:08 PM
Saginaw 4speed overdrive conversion (pics included) Shefron Transmission - Rearend 23 01-31-2006 10:52 PM
gm Saginaw 4speed transmission 4doorjoe Transmission - Rearend 4 01-01-2003 05:58 PM
