hurst shifter, saginaw 4speed shifting problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2014, 01:04 PM
i have a 79 Chevy c10 with a 350, Saginaw 4 speed and a Hurst shifter. i recently bought the truck. I was told there was a problem with the transmission and/or shifter. i pulled the tranny out, pulled the side cover and everything is in good shape. i installed new bushings on all the shift rods put the tranny back in and on the first drive i had some problems shifting in the gears. at a stop sign i attempted to shift into first but it wouldn't go. it was almost like it was stuck in 2 gears. after i was kinda rough with it it finally came out of gear. i drove it back to the house but was still having problems getting it into the correct gears. could somebody please point me in the right direction.
Old 02-02-2014, 01:11 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Welcome to Hotrodders
I edited the thread title. There is no need to beg for help here. Proper information in the thread title helps the membership help you
The Following User Says Thank You to Crosley For This Useful Post:
latimermichael88 (02-02-2014)
Old 02-02-2014, 03:32 PM
455olds's Avatar
Have you adjusted the shift rods position?
Old 02-02-2014, 04:00 PM
gettin closer
OK so i just crawled under and put a bolt in the shifter to hold the rods in the correct position. i had to adjust 3rd-4th gear rod about 8 turns to get it right. i had to adjust 1st-2nd gear rod 2 turns to get it right. now the problem im having is when i shift back to neutral from 4th sometimes it will try to stay in gear. Also it wont go into 1st from a stopped position i have to shift from 2nd to get it to go into 1st.
Old 02-02-2014, 04:01 PM
Wiki Edits: 27
shift adjust.
you align the shifter arms with a 1/4 in drill bit shank and adjust the rods
more info here
Four-Speed Hurst Shifter Install
Old 02-02-2014, 04:15 PM
does it have to be 1/4 in?
Old 02-02-2014, 04:55 PM
rechecked everything still havin an issue getting it to shift into 1st from neutral.
Old 02-02-2014, 08:52 PM
Wiki Edits: 27
more instructions
enlarge the exploded view in the Chevy, link the tool is item 17
in the following link item 3 is the 1/4 in L tool
http://www.jegs.com/InstallationInst...0-373-3163.pdf
in the hurst info you can see the 1/4 in L tool
I had a T 10 4 speed behind a small block Ford that looked good inside but I still had shifting problems, then changed engines to a 401 buick, auto.
Old 02-02-2014, 09:29 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
Its not in the shifter its the Saginaw trans (my opinion) they are notorious for this It needs refreshing a basic kit costs around 150 dollars if you have the ability to do it yourself. But if your paying a shop to do it, you may do better to find a good Super T 10 or Muncie M 22 or 21 they are much better transes! and a new saginaw runs about 800 dollars average!
The Hurst shifter for the Saganaw and installation kit has its own inherent problems Its just a crapy shifter when used with the adapter kit the stock saginaw shifter works better if not wore out and is easier to adjust.
Jester
Old 02-03-2014, 08:43 AM
I bet your slider, shift fork or the engagement teeth on the 1st gear are pretty worn. It'll need a rebuild. If you're on the east coast, I can recommend a few guys for parts
Old 02-03-2014, 01:00 PM
Jester
Old 02-03-2014, 01:19 PM
Has anyone considered the clutch may be dragging a bit. It sure will make one want to stay in gear as well as keep it from going into gear.
John
Old 02-03-2014, 02:00 PM
when i had the side cover off the shift forks looked good. although i probably should have measured them. the synchros looked worn but i thought they were probably still good. i was test shifting both ways. when it is not running it shifts a little smoother than when it is running. ill crawl under again and check my linkage again just to be sure. if i still cant get it figured out i guess ill pull the shifter out and take it apart and check for wear there. if it looks alright ill pull the tranny and check the clutch out. also i would like to thank all you guys for your help. much appreciation
Old 02-03-2014, 02:26 PM
Old 02-03-2014, 09:01 PM
heres what i got so far
ok so heres where in at. i pulled the shifter, drilled and tapped the holes for the stop bolts theraded the bolts in, bolted the shifter back in hooked up the linkages correctly. got in the truck, ran it through the gears and it was smooth like butter. then i start the truck run it through the gears and i have the same problem as before cant get 1st without going to 2nd and so on.
hurst, saginaw, shifter, transmission
Problems w/new shifter (4-spd Hurst) DaveWms Transmission - Rearend 3 05-30-2013 10:30 AM
Saginaw 4speed overdrive Ed Voss Transmission - Rearend 1 08-30-2011 08:23 PM
Saginaw 4speed Question razdude Transmission - Rearend 6 11-07-2006 06:08 PM
Saginaw 4speed overdrive conversion (pics included) Shefron Transmission - Rearend 23 01-31-2006 11:52 PM
gm Saginaw 4speed transmission 4doorjoe Transmission - Rearend 4 01-01-2003 06:58 PM
