Hurst T-handle - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2007, 06:47 AM
coupe66's Avatar
Hurst T-handle
Hi guys,
Before i destroy anything... how is the T-handle mounted on a Mr Gasket Pro-Matic shifter stick?
Is it just on threads ? So i just have to engage more force to get it loose, anticlockwise... ?!
Thanks!
/Pete
Old 04-01-2007, 09:00 AM
302 Z28's Avatar
I believe the Hurst aluminum T handle has 3/8" SAE female threads with a special locknut.
Vince
Old 04-01-2007, 09:44 AM
coupe66's Avatar
Could not see any "locknut" under the handle, hope a litte more force will loosen it then.
Thanks for the help!
/Pete
What will a TH350 Handle? Many Th350 Quetions, Shift kits? Warrant Transmission - Rearend 2 12-18-2005 10:46 PM
Back up light switch on a hurst indy 3 speed shifter junkyardjeff General Rodding Tech 3 11-02-2005 11:41 PM
Hurst Quarterstick Cable S10Fan Transmission - Rearend 2 03-12-2005 09:51 PM
how much a stock 350 can handle ChevyVan Engine 8 07-20-2003 06:55 PM
Door handle spring Lash Body - Exterior 2 01-13-2003 02:56 PM
