HVLP and gravity fed guns - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-03-2008, 04:26 AM
Is HVLP and gravity guns the same thing? A little confused.
Old 01-03-2008, 04:53 AM
garyroushkolb's Avatar
Last wiki edit: How to find an electrical drain Last photo:
They are not the same thing, pot location is the common thing, but they use far different pressures and act different when used. I'm sure someone with more knowledge will explain the difference better than me.
Old 01-03-2008, 05:39 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
Gravity gun just means the cup is on top and the paint flows into
the gun by gravity.
HVLP means High Volume Low Pressure-(they take a lot of air "volume")
They spray at a lower pressure at the tip-usually around 12 psi,
(The gun's inlet pressure is much higher, the gun itself lowers it at the tip)
Although most HVLP's are gravity,
HVLP and Conventional guns come in both gravity and siphon cups.
Old 01-03-2008, 08:25 PM
BMM BMM is offline
HVLP is 3-10 psi at the tip, at least for the seta's we use. Not all HVLP's are gravity feed, and not all gravity feeds are HVLP. Most tend to be, but.
Here, you must use a HVLP gun (50% transer rate or better), or one which achieves similar transer efficiensty. The gun will say if it's HVLP or not.
Low volume Low pressure paint gun 35olds Body - Exterior 27 06-28-2006 06:48 PM
Gravity vs Siphon jcclark Body - Exterior 5 03-18-2005 08:20 AM
These new fangled spray guns are kinda neet. Centerline Body - Exterior 4 12-30-2004 09:04 PM
Low CFM HVLP Spray Gun bmech211 Body - Exterior 8 04-18-2004 11:52 AM
Binks & Harbor Fright guns, tight quarters & spray booths TRACKMAN Body - Exterior 2 12-18-2003 07:46 PM
