HVLP - inverted painting - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-23-2009, 12:13 PM
Simple question to answer for most of you, but how do I paint with the gun upside down using a HVLP gun. Im trying to paint the floorboards inverted but gravity doest work that way. Thanks!
Old 08-23-2009, 12:40 PM
302 Z28's Avatar
There are only two ways you can paint upside down with any gravity feed gun. One is use a bag system inside the cup. The other is to figure out some way to invert the cup. Some gravity feed guns allow the cup to be swiveled to any position, some do not. The bag system is the easiest solution to this problem. With the internal bag system all air is sucked from the bag inside the paint cup, and as the paint is pulled from the bag it collapses.
edit: another method would be to have a remote cup arrangement.
Vince
Old 08-23-2009, 08:47 PM
cboy's Avatar
Last journal entry: Finished
Originally Posted by 302 Z28
... another method would be to have a remote cup arrangement.
I chose the remote cup method mentioned by Vince because I not only had to spray upside down, I had to spray in very tight quarters. Here's a shot of the gun in action. I made it from from old gun parts I had as shown in this thread.
Always learning...and sharing what I've learned.
Newbie with an HVLP paultsmith Body - Exterior 27 07-13-2009 07:16 AM
Hvlp ??????? S10 Racer Body - Exterior 9 05-22-2008 08:34 AM
HVLP painting. ggarvey Body - Exterior 3 10-02-2006 10:32 PM
Orange peel in the clear Montypierce Body - Exterior 13 03-06-2005 08:49 PM
HVLP painting IROC100 Body - Exterior 6 01-17-2005 10:53 AM
