hvlp set up - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2011, 11:20 AM
hvlp set up
hello i am trying to find out how to set up a hvlp spray gun to spray epoxy primer,basecoat and clearcoat? ive painted 20-25 years ago and always used my binks bottom sucker. things changed since then and im trying to keep up but its hard to get the gunset up for the first time. im using a 3 set of devilbis with a 1.8gun,1.4gun and a 1.0 touch up and ide like to know how to set these up please/
Old 05-25-2011, 01:49 PM
Scandinavian's Avatar
http://www.backfalt.fi/indexse
Last journal entry: Torque Converter
2.5 bar pressure when spraying. @ the nozzle! do they havr the digital pressure clock?
Old 05-25-2011, 01:56 PM
http://www.autobodystore.com/ms6.shtml
Old 05-25-2011, 02:01 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I use 90/100 psi at the wall and set my gun at about 30 psi at the handle which gives me roughly what I need at the tip. tape some masking paper to the wall and shoot some samples to see how well the gun is set up..I work to eliminate orange peel first and then work on the runs as are mostly gun technique and believe it runs are easier to fix even if I need to wash off a fender and have a do-over..
Here is an excellent writeup on gun adjustment..
http://www.southernpolyurethanes.com...your%20gun.htm
Sam
Old 05-25-2011, 04:04 PM
i dont see it on any of the guns. but in the manual it says recommended air pressure 29-51 psi (2.0-3.5 bar) and max air is 120psi (8.3bar).. does that help at all for you? now this is my clear gun with a 1.4 tip then i have the 1.8 gun and the 1.0 gun.
also how do i know the nozzle pressure when the last gauge is at the handle? and what should be the pressure at the handle?
thank you so much
barry
Sharp Titanium HVLP 1.4 and Astro HVLP for shooting epoxy, 2K, base and clear? 65-408 Body - Exterior 1 04-16-2010 01:31 PM
looking for HVLP gun runn141 Body - Exterior 8 02-05-2010 02:35 PM
max air hvlp runn141 Body - Exterior 0 01-25-2010 12:48 PM
Want a New HVLP Gun Irelands child Body - Exterior 1 10-14-2006 11:54 PM
Best HVLP gun! camaro freak Body - Exterior 40 03-11-2006 01:54 PM
