HVLP Spray Gun Question
Hi
Got a HVLP garvity spray gun and have been reading with interest how to set them up, correct inlet pressure, 2 1/2 turns out on the mixture screw...set the fan control out to what you want etc etc. However, i have 2 questions, no mention is made of the air inlet adjuster screw, what do you use it for? is it used at all?, and my second question, which in some way i feel is connected to my first, once you set the inlet pressure with a pressure gauge, common sense teels you to remove it so it doesn't get covered in paint, or damaged or knocked. Is this what the pressure adjuster could be used for? and if so, how do you set it to the pressure you need to get the 10psi at the cap I'm a bit confused, so any help would be appreciated Thanks Rich |
Set up is Fluid control Wide open and turned in till it just hits the trigger....Trigger pulled all the way back (full trigger) and set inlet pressure\\ Inlet pressure is th Pressure called for in the instructions..."inlet pressure" at the Gun 52F1 |
Kenseth
Thanks for the reply, I thought iwata were non cheapy guns..anyway, i see your point , getting the correct output is more than just setting all the gauges and knobs to manfs specs etc, but its a good starting point, its more about getting the right balance, i've learned that much!. And considering i'm UK based 'environmental-voc compliance' dont really apply.. I suppose it makes some sense to keep a gauge on the gun, as settings drift, etc you need to adjust things as you go along. Saw your Album, nice car, what is it?, us brits dont keep up with your cars to well. (edit) just seen the pic again, DOH! Mustang!!! Regards Rich |
I didn't mean to make it sound like I was saying an Iwata was a cheap gun. Quite the opposite, pricey, but worth the cost.
The cheapy gun I was talking about is one I bought in the meantime off of ebay, till I could buy the iwata. Probably more important then the gun you buy though is getting to know the gun you have, and what you need to do to get the best results from it. I don't know which mustang your talking about, but actually the silver and black mustang was cleared with the above mentioned cheapy gun, and the green one cleared with a conventional gun I had for years. I didn't pick up the iwata till afterwards. |
Hi
I get it with the guns.. as for the mustangs, they both look good, personally i prefer the older one, saw one at an Americana rally here some years back and i was hooked, I had a Chevy G20 DayVan back then... As you said, i think now its more important to get used to the equipment you've got. Regards rich |
| Not Another Spray Gun Question! | Workingwoods | Body - Exterior | 11 | 07-17-2008 02:07 PM |
| Which order do you want to have your regulator and filter in (on a spray gun)? | mikeweb | Body - Exterior | 3 | 02-27-2007 02:29 PM |
| Low CFM spray gun | tallpaul | Body - Exterior | 28 | 04-25-2006 10:59 PM |
| Best HVLP gun! | camaro freak | Body - Exterior | 40 | 03-11-2006 12:54 PM |
| Best Way To Clean A Clogged Spray Gun? | way_2fast_4u | Body - Exterior | 14 | 05-11-2005 02:46 PM |
