HVLP spraying with CO2 rather than air - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2006, 07:29 PM
Do modern paints require that they be sprayed with air, or would CO2 also work? I only ask because getting a cylinder of CO2 refilled is cheap, the output would be dry and cool, and there's definitely enough available CFM. Has anybody tried this?
CO2 would be a great alternative to a big compressor for people like me if it works.
Edit: how about Nitrogen?
Old 06-23-2006, 07:42 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Either would be fine for an airbrush.
But for a hvlp full size paint gun. Not much.
I think your confusing CFM with PSI.
Volume vs. Pressure.
It would work with a convintional gun for a short while but those regulators will not pass enough CFM to satisify a full blown hvlp gun for very long IMO.
Unless you got a railroad car size tank.
Old 06-23-2006, 08:18 PM
I didn't confuse flow vs pressure, but I did forget about restriction at the regulator. That looks like it would probably be the biggest problem.
Old 06-23-2006, 08:22 PM
Forget the regulator restriction problem, I just read that one pound of CO2 in liquid form equates to 7 cubic feet. That means a 20 pound bottle would be gone in a couple of seconds.
Old 06-23-2006, 10:58 PM
Edit--,made a mistake,pardon me.
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
Air Pressure jcclark Body - Exterior 5 03-03-2006 12:01 PM
shooting clear vinvango73 Body - Exterior 3 10-28-2005 11:24 PM
Hvlp Air Supply Kampr Body - Exterior 11 09-16-2005 10:47 AM
