Hyd clutch - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2005, 09:55 AM
Hyd clutch
I'm in the info gathering stage I'm converting my 63 to a manual from a auto. I have the factory pedal box, but I'm using a custom front frame so the hardware for the bellcrank is not there. So hyd is the way to go. Ok bell housing what is out there for a 350 with a 1.125" 10 spline clutch?
Thanks for the help.
Jon
Old 02-15-2005, 11:28 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
hyd clutch
Two ways to go..one is to mount the slave cylinder on the side of the bell housing using a fabricated bracket this is if the slave cylinder acts on the stock clutch arm....or you can get a hyd throwout bearing from Ram clutch and use that ..either way you do not need a new bellhousing..
OMT
