Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hyd clutch for early hemi
Old 10-28-2010, 10:36 PM
tjet tjet is offline
Hello, I'm in the process of building a '53 Chrysler 331 Hemi for my '59 Chevy pickup.
I'm working on some ideas for the hyd clutch setup. I have the Hot heads trans adapter for the extended bellhousing block (see below). I'm going to bolt up a Muncie 4 spd
This slave cylinder looks like it will bolt up to the side of the bellhousing ( #91025605)
What size master cyl would I need to use? The slave has a 7/8" bore, & 1.25" travel. I also need to attach it to the original clutch pedal, which goes down thru the floor.
hyd push cyl
Any advise would be great
I also attached a pic of an extended bell block as an example (not mine)
ID:	49353   Click image for larger version
