Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hyd clutch for early hemi
Old 01-01-2012, 08:50 AM
DeSoto DeSoto is offline
Hot Rod Wiring, Early Hemi SME
Use a '55 Chevy clutch fork and pivot.
You'll need to cut an access hole in the lower half of the bellhousing for clutch fork clearance.
Run your pedals through the floor, instead of on the firewall, and you can use mechanical linkage and do away with the slave cylinder. A simple clutch pedal with an arm extending downward below the pedal arm will pull a rod connecting the clutch to the fork. Almost a no-brainer.
