Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hyd clutch for early hemi
Old 01-01-2012, 08:54 PM
Centerline Centerline is offline
Wiki Edits: 49
Originally Posted by tjet
Centerline, that is a clean setup. If possible, can you take a pic of the master cyl installed and how the pedal attach?
Do they still make those pedals?
That master cylinder & slave are both for that '61 chevy pickup as you mentioned?
Yes they are both for a '61 Chevy pickup. The pedal assembly is still available from "The Hot Rod Company" I believe. You may be able to find it elsewhere as well. Its a reproduction of the original which was made back in the 60's. I'll take a pic of the master cylinder and pedals and post them tomorrow.
Centerline
HotRodsAndHemis.com
"If money is what makes cars fast, mine otta be going 400 miles an hour!". - Felix Sabates
