Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hyd clutch for early hemi
Old 01-02-2012, 03:34 PM
Centerline Centerline is offline
Wiki Edits: 49
Here's your pictures.
Master cylinder installed. This is the same unit used on the American Graffiti Coupe.
Complete pedal assembly. The washers were added to give a little more clearance for the steering column.
Close up of the push rod connections.
Centerline
HotRodsAndHemis.com
"Remember, if you didn't put it together with your own hands, its not really yours." - Tim Allen
