Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hyd clutch for early hemi
Old 01-04-2012, 08:06 AM
waltmail waltmail is offline
I converted my 65 Ranchero from a C4 auto tranny, to a T5 setup. Used a Ram hydraulic bearing setup with a Wilwood master cylinder, obtained from Speedway Motors. No fork, no linkage necessary. Just uses a braided steel flexible line. Used a Heim joint and threaded rod for engagement from the swing pedal. Works very nicely, without having to worry about clutch linkage clearance through the headers. Neat, efficient and relatively inexpensive.
Name:	2011-07-28 10.30.09.jpg
