Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hyd clutch for early hemi
Old 01-04-2012, 11:39 AM
Centerline Centerline is offline
Wiki Edits: 49
Originally Posted by waltmail
......Used a Ram hydraulic bearing setup with a Wilwood master cylinder, obtained from Speedway Motors. No fork, no linkage necessary.....
And if that throwout bearing ever goes our or leaks you'll have to pull the trans to replace it. Hydraulic throwout bearings are way more trouble than they're worth.
Centerline
HotRodsAndHemis.com
"The only place you'll find a helping hand is at the end of your own wrist" - Joe "Dr. Olds" Mondello
