Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hyd clutch for early hemi
Old 01-04-2012, 12:41 PM
waltmail waltmail is offline
Originally Posted by Centerline
And if that throwout bearing ever goes our or leaks you'll have to pull the trans to replace it. Hydraulic throwout bearings are way more trouble than they're worth.
"The only place you'll find a helping hand is at the end of your own wrist" - Joe "Dr. Olds" Mondello
To each their own. In my case, it was the best option. I am running headers that would interfere with any external slave unit. If any throw out bearing goes out, the tranny has to be pulled. I can pull and reinstall my transmission in less than 2 hours. So far, so good for me. I like my set up.
