hyd. clutch install need help - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2012, 06:07 PM
ive in the works in rodn a 57 3100 chevy im putting the power brake in the truck that will be under the floor (stock location) , but there saying will not work with stock clutch pedal . i was planing to use stock petal an under the truck conect it with a rod to a small mastercylinder , does any one out there had this issue ? what should i do? i want a hyd. clutch and power brakes and want petals in stock location !
Hyd clutch for early hemi tjet Transmission - Rearend 15 01-06-2012 02:06 PM
Do I need a stop for my hyd clutch? Mike Britton Transmission - Rearend 5 11-13-2006 07:25 AM
Hyd clutch 1963duce100 Transmission - Rearend 1 02-15-2005 11:28 AM
Bellcrank or Hyd Clutch? 6t6novass Transmission - Rearend 1 06-10-2004 10:25 AM
hyd clutch 2112jb Transmission - Rearend 4 04-29-2004 06:19 PM
