Hyd flat tappet cam valve ajustment???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2010, 08:47 PM
sbc, i run the engine and while its running i loosen the valve till it starts to tapp, then i run it back down till it stops taping then a 1/4 more, guys @ work say more it would run faster in drag raceing?? any ideas???
Old 06-13-2010, 10:31 PM
gofastz,
If they are not making any noise leave them alone.
Scholman
Old 06-13-2010, 11:23 PM
techinspector1's Avatar
Wiki Edits: 326
Originally Posted by gofastz
any ideas???
Yeah, tell the guys at work to pay attention to their work.
Old 06-14-2010, 03:53 PM
lol yal r crazy, i just got off the phone with "Mark" our cuzn the side of the family thats in the machine shop bussness, he said the GM book says 2 rounds to preload the lifters, he was tellin me with set up im runing to go 1/2 round after tapping to preload the lifters?? some reason iv always do the 1/4 round??
Old 06-14-2010, 04:03 PM
ericnova72's Avatar
More for Less Racer
Two rounds will be way to much and will come close to bottoming out the lifter plunger, if it doesn't hit bottom before you get that far. Something between 1/8 and 3/4 is what almost everyone uses.
Old 06-14-2010, 04:33 PM
I've gotta agree....two rounds is way too much. We always ran 1/4 to 1/2 a round. Worked fine.....
Old 06-14-2010, 05:20 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Using 3/8-24 studs and 1.5 ratio rockers, two full turns would be about 0.125" (1/8") of preload- too much.
Old 06-14-2010, 08:00 PM
and valve floating here it comes, from what gather the lifters are pumping up hard @ idle, and most of the time when the valves are tighter you limit the rpm's the engine can turn...iv had engine buliders tell me 1/4 turn is the best set, for the street and race for the hyd flat tappet cams!
can any gurus explain "roller" v8mazda Engine 18 04-25-2010 03:12 PM
Cam or Lifter Trouble (Hydraulic Flat Tappet) Jackson72ss Engine 2 04-06-2010 07:29 PM
Flat tappet vs. Roller cam turchiac Engine 8 02-18-2010 12:33 PM
I lose compression w/ valve adjust drivehard Engine 5 11-23-2009 09:29 AM
.485 lift solid flat tappet cam....screw in studs needed? flyin99 Engine 12 05-12-2006 07:41 PM
