Hyd floor jack - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-10-2008, 07:29 PM
Hyd floor jack
This is my 1st thread on garage tools. I have "sears" jack,its about 10 yrs. old. the handle return spring broke. Mr.sears @ roebuck told me they do not sell parts for their jacks. Ain't that some s---. I told them in so many words, that sucks.I am wondering if anyone can tell me where I can find that spring I know there's plenty of knowledge on this site
As always Hotrodders BB is
Jim Dandy
Old 01-10-2008, 08:03 PM
302 Z28's Avatar
I would check with some hydraulic repair shops in your area. Look in the phone book for hydraulic cylinder repair.
Vince
Old 01-10-2008, 08:06 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
The big problem is (usually) that it just doesn't make economic sense to fix some of the cheaper jacks. Most of the hydraulic equipment places in the city (Calgary) charge $100.00+ per hour to fix anything.
I know, I know ... you just want the parts, and you will install them yourself ... right?
Yes, me too ... but unfortunately the "DIY" customer component is almost negligible percentage of their business ... which means that stocking repair parts is no longer profitable.
Another factor is that many of these "consumer" (versus "professional") products are designed to be pretty much non-serviceable. The pump bores and cylinders are cast in aluminum, with no sleeves. when they wear out ... buy a new jack.
Sadly, that is why we are becoming a "throw-away" society.
So it seems our choices are to either shell out the big bucks for a "professional grade" jack, or buy another "el cheapo".
If you are looking for a new jack (either way) have a look at one of those "easy up" syle. They have a 2-stage pump that usually raises the lift arm to the point of contact in one or two pumps, and then the second stage takes over and does the "grunt" work.
Here is a link to an OTC #1717 jack ... and yes, you can get repair parts for this one.
Here's another thought. Perhaps you're lucky and the spring you need to fix your jack might be the same as the one that fits one like this. there is an online (PDF file) owner's manual / parts list on that page as well.
Old 01-10-2008, 09:01 PM
What does that spring do?
Old 01-11-2008, 05:57 AM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
I have a Sears that must be 25-plus yrs old....I love it even though it is the first of the asian imports from Sears.
I assume it is a coil spring with two tangs. I'd bet there is a spring manufacturer out there that lists all sorts of sizes of those. But I am sure there is a certain name for that style of spring and I have no clue what to type into google.
I'd stop by a hyd repair place...they may have a spring that could work...as most imports are knock-offs of another brand.
Old 01-11-2008, 08:05 AM
Dugg's Avatar
My compass doesn't point North
I work part time in a hardware store.... Yes Paris, I'm your helpless hardware man.
Most hardware stores carry a variety of tension and compression springs.
Improvise!
Old 01-11-2008, 08:30 AM
poncho62's Avatar
Wiki Edits: 5
Improvise!
Yeah...you can probably make your own. If it needs hooks on the end, heat it up to bend.
Dugg.......You gotta get Paris off your mind......
Old 01-11-2008, 12:48 PM
did you call sears parts? If you spoke to someone at the store you may have received an idiot . Call the store and ask for the sear parts phone number. You should be able to order any replacement part you need and have it shipped to you. At least, thats how it worked when I worked there in hardware about four years ago. It could have changed, who knows. At the time I used the hotline once to order a direct re-placement vent fan for a 10 year old panasonic surround sound receiver that was not purchased at sears. Thats a pretty obscure part, I was impressed to say the least.
Old 10-22-2008, 11:35 AM
repair for all floor jacks & battery chargers too!
Hello!
i have 3 floor jacks 2 walker & 1 sears floor jack ! i found a repair shop farmingdale long island NY ! he repaired walker jack rebuilt hydraulic jack did a nice job & the other walker jack has bent frame & fixing now ! he said that repair all types & brands jacks floor or bottle & battery chargers too !! very reasonable cost!! check out his website !!
AUTO-MATIC REPAIR COMPANY
Kiddbrother
Old 10-22-2008, 05:17 PM
repair for floor jack
Go to Sears (Craftsman ) web site, type in model # of your jack, look at parts breakdown, order spring. OR take spring to ACE hardware and match up with a new one.Just did that for my Cycle Country snow plow to replace the trip springs. 2 springs, $20.00 and I'm done. No special order, no waiting,no shipping charges and best of all, no BULL!!! More than one way to pluck a duck.
Hyd. Roller lifters problems hotrodf1 Engine 121 10-25-2007 01:31 PM
Do I need a stop for my hyd clutch? Mike Britton Transmission - Rearend 5 11-13-2006 07:25 AM
plz help,,,1988 vette 350 hyd roller motor can i convert it to hyd non-roller?? tiresmoke55 Engine 20 05-24-2006 01:51 AM
Stock GM Cam Specifications bluesman123 Engine 10 02-16-2004 08:13 AM
What's a "Mild Hyd Cam?" horvath General Rodding Tech 6 05-22-2003 02:34 PM
