Hyd roller cam with iron heads.
I have a question about running a hyd roller cam with my cast iron heads. I am running a set of 291 double hump heads. They have changed to 2.02 intake and 1.60 exhaust. They have screw in studs. I have changed out the 1.25 stock springs for .600 max lift single springs with damper. I have been running a .525 solid lift cam, but would like to upgrade to a hyd roller around the same lift. My question is can I do this with the springs I have on my heads? They are on a 383 stroker motor with an Eagle rotating assy. Thanks for your time.
Thanks guys. I have been told that to run a roller cam that I needed to have atleast 1.40 od double springs on my heads.
I'd call the cam company. They are the best ones to ask for the particular cam. Just have the spring pressure and size ready for them and tell them the specs of the cam you are wanting to put in.
Thanks again. My only concern was the OD size. But i figured that if the cam is not more than .600 max lift that it should be fine. The springs I have are 130 lbs. of seat preasure. Going to take them to the machine shop tomorrow to have them checked just to make sure before i buy a cam.
| Would roller lifters work without a roller cam? | DEMONSPEED | Engine | 4 | 11-08-2009 04:44 AM |
| Right cam for a 383? | atomicrockerdude | Engine | 23 | 11-02-2009 12:13 AM |
| BBC Hyd Roller Cam Kit | jr2009 | Engine | 5 | 07-26-2009 08:16 PM |
| Anyone have issues with comp cam xtreme energy roller cams for street? | eric32 | Engine | 6 | 05-24-2009 02:03 PM |
| Do oem 350 sbc roller cam's take the same cam bolts as older ones? | eric32 | Engine | 5 | 04-20-2009 04:12 PM |
