Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hyd. Roller Lifter Check.....Check
Old 07-21-2009, 01:03 PM
greenmoonshine's Avatar
greenmoonshine greenmoonshine is offline
Hyd. Roller Lifter Check.....Chech
What is the best method to check a set of used roller lifters?
I had read an article on this somewhere but not sure where....I did a search and turned up a thread on rebuilding them but the pics. were broke and there was some talk about how that wasn't a rebuild,it was just a good cleaning and inspection.The article I read had mentioned something about rolling each one either down your fingernail or arm (cant remember which) and if it catches or stops rolling.....there bad......but like I said I cant find that article and was wondering if any of you have your own tips or tricks to this.....
I am thinking about just getting a set used with the rollers,dog bones,and spider so I can have the roller set up and wanted to check all of the rollers so I can just replace the ones that are worn or bad......I figured that this would be the most cost efficient way of converting......
