Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hyd. Roller Lifter Check.....Check
Old 07-21-2009, 07:56 PM
greenmoonshine's Avatar
greenmoonshine greenmoonshine is offline
O.K.,sorry for the confusion but the block is a 87 350 that is set up from factory for a roller but came with a hyd. flat tappet cam and does have the bosses for the spider(just need drilled and tapped) along with the holes to bolt on a cam retainer plate.
here is a pic.
now back to the question at hand, How to check the used roller lifters to see which ones are all right and which ones need to be replaced?
Thanks
GM
