Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hyd. Roller Lifter Check.....Check
Old 07-22-2009, 11:58 AM
BogiesAnnex1 BogiesAnnex1 is offline
Originally Posted by greenmoonshine
O.K.,sorry for the confusion but the block is a 87 350 that is set up from factory for a roller but came with a hyd. flat tappet cam and does have the bosses for the spider(just need drilled and tapped) along with the holes to bolt on a cam retainer plate.
here is a pic.
now back to the question at hand, How to check the used roller lifters to see which ones are all right and which ones need to be replaced?
Thanks
GM
With any lifter new or used, you puts down your money and takes your chances. Unless really gouged or gunked up inside there really isn't much to learn by taking them apart, and usually doing that to clean them is a 50/50 proposition that a perfectly good lifter will be made into junk by the time you're done. So you need to decide what is the risk against the cost of replacing a lifter or two after the engine's assembled and installed.
Given a new set of GM roller lifters can be had for 120 bucks, it seems the cost and effort of digging a failed lifter out isn't worth the risk of unknown used lifters.
Bogie
