Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hyd Roller lifters
Old 10-12-2006, 11:48 PM
underdog305's Avatar
underdog305 underdog305 is offline
The wear pattern on the old cam was good. Every lobe wear pattern was right in the center. The engine spun a #1 Rod bearing and cut a .050 groove in the crank. There was lots of metal in the pan. Pumping and flushing them in clean oil should prep them for re-installation without worries right?
