Hyd roller vs Hyd flat tappet for sbc
Been reading like crazy the past month and thought I've decided on lunati's "268" cam "Basic Operating RPM Range:1,800-6,200
Intake Duration at 050 inch Lift:227 Exhaust Duration at 050 inch Lift:233 Duration at 050 inch Lift:227 int./233 exh. Advertised Intake Duration:268 Advertised Exhaust Duration:276 Advertised Duration:268 int./276 exh. Intake Valve Lift with Factory Rocker Arm Ratio:0.489 in. Exhaust Valve Lift with Factory Rocker Arm Ratio:0.504 in. Valve Lift with Factory Rocker Arm Ratio:0.489 int./0.504 exh. Lobe Separation (degrees):110" but I have the opportunity now to pick up comps "276" Hyd roller Basic Operating RPM Range 1,900-5,600 Intake Duration at 050 inch Lift 224 Exhaust Duration at 050 inch Lift 230 Duration at 050 inch Lift 224 int./230 exh. Advertised Intake Duration 276 Advertised Exhaust Duration 282 Advertised Duration 276 int./282 exh. Intake Valve Lift with Factory Rocker Arm Ratio 0.502 in. Exhaust Valve Lift with Factory Rocker Arm Ratio 0.510 in. Valve Lift with Factory Rocker Arm Ratio 0.502 int./0.510 exh. Lobe Separation (degrees) 110 My goal is to run high 12's (12.99999 is ok with me) my platform is a 64 chevelle SS with a gm goodwrench 350 stock bottom end eddy performer rpm heads rpm intake Holley 750 vac secondaries backed by a th350 with a shift kit 2k ish stall 3:73 12 bolt posi. I would like to keep the p/b What do you guys think about the cam choices? Am I totally off base here for my application? |
And the heads are 185 intake 64cc chamber with eddys .38 head gasket
What is the static compression ratio of the motor?
Hey tech inspector I've read a lot of your posts and was hoping you'd chime in, I'm fairly new to this but using a couple calculators online I was getting a DR and SR in the mid 5's with the 64cc heads .38 gasket stock deck and piston volume and using the 39.5 ABDC from lunati's cam card... I hope I'm making a mistake because that doesn't sound right to me...
Thanks SSedan now that ive gotten some sleep and have some coffee on board I noticed on my numbers I was missing a "0" in front of my .38 headgasket haha
A motor with 9.00:1 SCR will make good cylinder pressure with a cam that closes the intake at somewhere between..... 15 degrees ABDC @0.050" tappet lift = 8.62:1 DCR 20 degrees ABDC @0.050" tappet lift = 8.48:1 DCR 25 degrees ABDC @0.050" tappet lift = 8.32:1 DCR 30 degrees ABDC @0.050" tappet lift = 8.14:1 DCR 35 degrees ABDC @0.050" tappet lift = 7.93:1 DCR A cam that closes the intake at 39.5 degrees ABDC @0.050" tappet lift would work this way with these static compression ratios.... 10.00:1 SCR, 8.58:1 DCR 9.80:1 SCR, 8.41:1 DCR 9.60:1 SCR, 8.24:1 DCR 9.40:1 SCR, 8.07:1 DCR 9.20:1 SCR, 7.90:1 DCR SJSS, let me help you a little with numbers.... .38 is three hundred and eighty thousandths, or about 3/8ths of an inch. .038 is thirty eight thousandths of an inch. .0038 is thirty eight ten thousandths of an inch To be technically correct, you need to put a zero in front of the decimal point if there is no whole number involved, like this.... 0.038" thirty eight thousandths of an inch |
| flat tappet to roller cam | toddtheodd | Engine | 29 | 02-06-2007 06:06 PM |
| Flat tappet to roller cam | johnc486 | Engine | 5 | 09-21-2006 04:50 PM |
| Flat tappet vs roller | Huskinhano | Engine | 21 | 07-23-2006 11:03 PM |
| Roller cam vs. Flat Tappet cam | Half Breed | Engine | 4 | 01-11-2006 08:31 PM |
| Flat tappet VS. Roller cam | 67 Deuce 4 Me | Engine | 15 | 11-13-2005 03:24 PM |
