Hydraulic Brakes for vintage chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-07-2008, 12:01 AM
need strog32 chevy front doors
Last journal entry: Tbd
Can some one inform me about how to put 1950's sprindles and later backing plates on my 1932 chevy front axle.
What need to be done and what years work
Old 09-09-2008, 06:19 PM
Wiki Edits: 27
spindle swap
I have done it, the thing to check is king pin size dia and length. and king pin angle I had a shop press in new bushings for king pins and size them to fit. if the wheel camber angle is wrong alignment shops that do trucks have tools to bend the axle. It's best to find spindles that match to old angle.
Old 09-09-2008, 06:25 PM
Wiki Edits: 27
kspindle swap
I did an AMC swap to a ford.. a magazine said it was easy. amc spindle stubs have 4 bolts, I cut off the ford stub in a lathe and redrilled the ford 4 holes than make a filler plate because i didn.t like the way it looked ... a lot harder than the magazine said ... I saw the Amc disc brakes and a 20's dodge at a show it looked easier than mine try at it.
looking for juice brakes for my 31 chevy RGassman Suspension - Brakes - Steering 4 06-04-2014 08:49 AM
58 chevy belair 4 wheel disc brakes change over Rick England General Rodding Tech 1 02-22-2006 09:40 PM
28 Buick hydraulic brakes bbflynn Suspension - Brakes - Steering 2 11-20-2003 08:04 PM
Disk Brakes for 3/4 ton 1966 Chevy P.U. big_daddy6464 Suspension - Brakes - Steering 4 10-21-2003 03:12 PM
Hydraulic clutch for1972 chevy pickup Dan Drone Transmission - Rearend 6 10-13-2003 09:28 AM
