Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hydraulic cams - flat versus roller - revisited
Old 11-16-2006, 12:24 AM
lust4speed's Avatar
lust4speed lust4speed is offline
Roller cams act like a hydraulic cam 10 degrees smaller in manners. I can run a mechanical roller with 246/252 @ .050 and still have plenty of vacume for the power brakes. Same with the hydraulic roller having manners like a much smaller flat tappet hydraulic. Since you can run a cam 10 degrees larger and have the same street manners, it seems that it would be fair to run the test with 10 a degree larger roller cam.
