Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hydraulic cams - flat versus roller - revisited
Old 11-16-2006, 05:13 AM
k-star k-star is offline
Last journal entry: PICTURE TEST
Originally Posted by hotrodf1
Don't forget - plenty a guy has fragged a roller lifter as well!! It happens. In fact, Comp Cams says that you should periodically check the rollers, axles, bearings for cracks, wear, etc when you get a set of their Magnum lifters.
Yes roller lifter failure is something that can happen, but in the mild hyd roller cams i think it's a none issue...I would bet you can't find 5 guys on this site that lost a roller on a mild hyd roller cam,,,but you can find 10 times that amount that lost a flat tappet lobe...IMO the odds are against you on that one...
Now a solid roller with 1000 lbs over the nose,,,thats another story!!!
keith
