Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hydraulic clutch bleeder screw
Old 06-29-2009, 08:59 AM
henny496 henny496 is offline
I have a hyd clutch master and slave from a mid to late 80's Camaro
It is new and this is in a custom application. The slave is higher than the master(floor mounted pedals)
There is a brass set screw (bleeder screw)on the slave cylinder that has an allen key head
I am by myself doing this, tried all day yesterday to bleed it, had it close once but then lost it later trying to get the last of the air out
I have a vacuum pump, but I would need some type of conventional bleeder screw to go in place of the set screw.
Does anyone know what bleeder screw will work , so I can do this myself with a vacuum pump. The threads are course...looks like 5/16 -18 but I wonder about metric......just don't know and frustrated
I need an extra arm and a leg to do this the conventional way,,...and the dogs won't help
