Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hydraulic clutch bleeder screw
Old 06-29-2009, 10:06 AM
henny496 henny496 is offline
Thanks Cobalt and Brian 59 for your replies
I will go back out , take off the slave and rebleed the line and master. I will then push the rod in and out of the slave with a hose from the line fitting a can of brake fluid, then put it back on
I will still have some air, but I can pump the pedal and then cut a 2x4 to jam between the cage and the pedal to hold it down. I am just afriad of the pedal releasing once it gets pressure causing the board to fall.then air in the system, but maybe a bungee cord back up somewhere may help
(Brian59 ) The master has the mounting flange on a 45 * angle and the slave bolts on at a 90* angle. The car is already up on stands , so I cannot move it(other parts I am waiting on)
thanks again
