Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hydraulic clutch bleeder screw
Old 06-29-2009, 02:52 PM
henny496 henny496 is offline
I went to the local auto parts store and got a 10 mm bleed screw for brakes. I measured against the set screw and all I had to do was carefully grind the point off the bleed screw, so it has a flat bottom, the same as the set screw
Now I can vacuum bleed it
this hyd clutch has been a pain in the butt..I hope it has been worth the effort
it did not work....I give up for today
