Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hydraulic clutch bleeder screw
Old 06-29-2009, 06:26 PM
henny496 henny496 is offline
Thanks for your reply T-bucket
I had gone back out, took the slave off again and submersed it into a container full of brake fluid, then pushed the rod back and forth until all the air was out of it(left the slave in the container of brake fluid)
I then put the high pressure line from the master into the container and pushed the clutch in an out many times until I was sure not more air was coming out
I then connected the line and slave, while both were still submersed in the brake fluid
.......very messy, but I think I got it
I have to bleed the brakes tomorrow, so may be using the wood idea if the vacuum pump gives me a headache, and at this point I am expecting more headaches lol
thanks again
