Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hydraulic clutch bleeder screw
Old 06-29-2009, 08:04 PM
Henry the 32nd Henry the 32nd is offline
With the slave higher than the master, the fluid likely will drain back into the master from the slave so don't forget a residual valve [1 way] in the line
