Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hydraulic clutch bleeder screw
Old 06-29-2009, 08:18 PM
henny496 henny496 is offline
I had asked about a residual valve but was told it may infere with the action of the clutch
My brakes have residual valves (2 psi) but the resovior on the master cylinder is connected to the master. The hyd clutch has the resovoir on the firewall, making it the highest point
The master for the clutch and brakes are floor mounted and behind the pedals
I went out and tried the clutch after my last reply and although it does not appear like a lot of travel, I put it in gear to try it with and without the clutch(board holding down the pedal) It does work ok and I can move the driveshaft with my hands when the clutch is depressed
I do feel happy with this and want to thank you guys for all of your input and advice.
thanks again
