Hydraulic clutch linkage??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2005, 03:02 AM
84Z 84Z is offline
Gas Raper
Hey, this could be a very stupid question, but in that case it will be very easy and short to answer. Anyways, I have an 84 camaro witha hydraulic clutch linkage. I'm dropping in a big block and would like to mate a built "m22" ( I say that cause it's not really one). Lakewood has a bellhousing which would connect the trans to the big block without killing the hydraulic setup. I was told I would need a bigger clutch assembly with 10 spline to work with the "m22" vs having a smaller clutch with 26 spline. So my question is, can I just buy a bigger clutch to work with the trans, and the hydraulic sysetm will work fine with it, or will I have to get a mechanical clutch linkage to workt he new clutch. If neither, what would I need to do. Thanks.
Old 05-31-2005, 09:44 AM
johnsongrass1's Avatar
Race it, Don't rice it!
10.4/5 inch will be the biggest clutch you can fit into the bell. Buy a clutch that will mate with your input shaft spline wether that is 10/14/26 splined. You hyd. slave should be able to compensate for any minor changes to geometry.
Model A Tinker Toy clutch linkage ? Mickey Miller Transmission - Rearend 2 08-09-2005 03:34 PM
Firebird and Camaro clutch linkage BanditT/A Transmission - Rearend 1 10-25-2004 09:13 PM
Hydraulic clutch linkage 6t6novass Hotrodders' Lounge 2 06-05-2004 05:48 PM
hydraulic or mechanical clutch linkage? Pharmy Transmission - Rearend 5 03-31-2004 08:10 PM
clutch linkage!!? chevyelc81 Transmission - Rearend 11 08-01-2002 06:46 AM
