Hydraulic Clutch Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2013, 10:44 AM
I'm setting up a hydraulic clutch on a 327 Chevy with Muncie. This is a retrofit into a 62 Studebaker. Stock type diaphram clutch, and have a question. I'm using a Novak hydraulic slave kit which has a total of 2.1" stroke. The master is a Wilwood compact with 1.4" stroke, so I am going to get a maximum of 1.4" stroke at the slave because they are both 3/4" bore and Novak tells me I will get 1 to 1 ratio. I know that there is also a ratio on the clutch fork that comes into play, but I don't know for sure what it is. I got the stock style Chevy fork with the kit from Novak. Will this be enough to disengage the clutch?
Hydraulic Clutch Question Dougie Transmission - Rearend 2 04-09-2012 10:39 PM
Help with a Hydraulic Clutch onenew32 Transmission - Rearend 4 07-05-2007 09:09 PM
hydraulic clutch TBear Hotrodding Basics 9 10-30-2006 06:51 PM
Hydraulic Clutch Blazin72 Transmission - Rearend 5 03-31-2006 09:47 PM
hydraulic clutch martion Transmission - Rearend 9 03-26-2003 02:37 AM
