-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   Hydraulic Cylinder Repair- Tranny Jack (http://www.hotrodders.com/forum/hydraulic-cylinder-repair-tranny-jack-169644.html)
123pugsy 12-08-2009 05:49 AM
1 Attachment(s)
I've got a seal kit for my tranny jack, but I can't get the nut open.
I've got it clamped with a vice grip chain clamp, but still doesn't hold it and the whole cylinder spins with the nut.
Any tips??
burnt olds 12-08-2009 10:05 AM
whats on end you have wrapped ? if a hole through it ,put a steel rod through it to hold from turning .
123pugsy 12-08-2009 12:51 PM
No hole under there. :(
burnt olds 12-08-2009 01:11 PM
leather strap wrench instead of chain .
also by squeezing near nut , is it by chance causing it to squeeze tighter .
deep socket on air tool with torque to whip it off .
123pugsy 12-08-2009 06:20 PM
An impact sounds like the way to go.
They don't make these things left hand thread by any chance , do they?
001mustang 12-09-2009 01:06 AM
Good idea; the vise grip has little surface area in contact.
Perhaps:
Clamp nut in a vise; not too tight.
Wrap shaft with tape.
Wrap leather belt on top of tape.
Use a large pipe wrench on top of the leather.
Cooling shaft with compressed O2 will also help.
001mustang 12-09-2009 01:14 AM
Probably an illusion but the threads appear to be left handed in the photo.
Make sure and verify the threads are right handed as 123 said.
123pugsy 12-11-2009 06:32 PM
1 Attachment(s)
Well, I finally got it.
Took the whole assembly out from the jack and clamped it in the vice.
Heated up the nut with a propane torch and it must have melted the Locktite on the threads.
I have no idea why there would be locktite there.
