Hydraulic Cylinder Repair- Tranny Jack - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-08-2009, 04:49 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
I've got a seal kit for my tranny jack, but I can't get the nut open.
I've got it clamped with a vice grip chain clamp, but still doesn't hold it and the whole cylinder spins with the nut.
Any tips??
Name:	IMG_0323 (Small).jpg
Old 12-08-2009, 09:05 AM
whats on end you have wrapped ? if a hole through it ,put a steel rod through it to hold from turning .
Old 12-08-2009, 11:51 AM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
No hole under there.
Old 12-08-2009, 12:11 PM
leather strap wrench instead of chain .
also by squeezing near nut , is it by chance causing it to squeeze tighter .
deep socket on air tool with torque to whip it off .
Old 12-08-2009, 05:20 PM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
An impact sounds like the way to go.
They don't make these things left hand thread by any chance , do they?
Old 12-09-2009, 12:06 AM
001mustang's Avatar
Good idea; the vise grip has little surface area in contact.
Perhaps:
Clamp nut in a vise; not too tight.
Wrap shaft with tape.
Wrap leather belt on top of tape.
Use a large pipe wrench on top of the leather.
Cooling shaft with compressed O2 will also help.
Old 12-09-2009, 12:14 AM
001mustang's Avatar
Probably an illusion but the threads appear to be left handed in the photo.
Make sure and verify the threads are right handed as 123 said.
Old 12-11-2009, 05:32 PM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
Well, I finally got it.
Took the whole assembly out from the jack and clamped it in the vice.
Heated up the nut with a propane torch and it must have melted the Locktite on the threads.
I have no idea why there would be locktite there.
Name:	IMG_0333 (Large).jpg
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
3 ton floor jack repair quick50stng Garage - Tools 4 09-03-2007 09:24 PM
Aluminum Cylinder Head Repair ssmonty Engine 2 03-11-2007 10:58 AM
cylinder head repair TIM LIMES Engine 6 07-16-2003 02:56 PM
Bleeding Wheel cylinder on a 91 corolla ramvrao Suspension - Brakes - Steering 1 03-20-2003 03:38 PM
