Hydraulic hose OK for compressed air? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2008, 05:10 PM
Harbor Freight has Hydraulic hose rated at 3500 psi, 4' long. I want to use it between my compressor and air delivery pipe system (for anti-vibration purposes) Regardless of quality of HF, I just want to know if hydraulic hose is OK for air? Is there anything about it that would contaminate the air? thanks
Old 08-18-2008, 05:56 PM
hydraulic hose
yes that is what I have wxcept mine is stainless steel braided hose got it for free so could not say no!!!! hydraulic hose is perfect
Old 08-18-2008, 06:30 PM
You bet it will work, probably the best choice of most anything you could use.
Old 08-18-2008, 07:11 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Yep...it will work good. Hydraulic hose usually comes two ways...single braid and double braid. The double braid is the best.
Old 08-19-2008, 12:03 AM
Well coming from you three, I feel very sure it will be OK. thanks for taking the time to help me. Bartamos.
Old 08-19-2008, 01:19 PM
On the first page on the bottom of the writing I have the specs on a hyd hose.
http://www.1969supersport.com/draw1.html
Rob
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
Bad Air Valve black66 Electrical 8 04-12-2005 12:44 PM
Fresh Air Respirator(sorry long) J Cal Garage - Tools 12 07-17-2004 01:46 AM
K&N air filters may void warrantees. Jmark Engine 0 05-05-2004 10:40 PM
Air Pump hose Jag Daddy Engine 2 11-17-2003 06:52 AM
