hydraulic lifters - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2005, 05:53 PM
Matts99Sierra's Avatar
hydraulic lifters
after you pump up the hydraulic lifters how easy should it be to push the valve down? and is there any certain way to adjust the valves with hydraulic lifters and roller rockers? thanks.
Old 03-05-2005, 06:18 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
http://hotrodders.com/kb/engine/articles.html#valve_train
Luv the smell of NITRO in the morning.
Old 03-05-2005, 06:21 PM
lluciano77's Avatar
I was trying to look that up in the knowledge base. It is a lot easier to find things now that the outline has been set up. The search engine still brings up a ton of info that I could care less about. It would be nice if the outline would have even more specific categories going down to valvetrain articles.
Old 03-05-2005, 06:37 PM
ok thanks
Old 03-05-2005, 07:01 PM
1BAD80's Avatar
Wiki Edits: 2
You heve to go thru the steps to find it.
Knowledge Base, Engine, Articles, then it gives a choice of Articles hit #14 for valve adjustments.
There is almost something for every car.
Old 03-05-2005, 11:41 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
manufacturers recommendations
alot of manufacturers recommend you not pump them up before adjusting. if you over tighten you may clip a piston. i always prime motor after it is built.
Old 03-05-2005, 11:46 PM
lluciano77's Avatar
I usually run the engine for a few seconds with all the rocker arms loose to pump them up. Then I adjust them with the engine off.
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
How to tell hydraulic from solid lifters? frankenvette Engine 3 05-24-2004 06:20 PM
REBUILDING HYDRAULIC LIFTERS NAIRB Engine 103 05-22-2004 03:40 AM
Hydraulic Lifters Vista Cruiser Engine 8 02-19-2004 10:09 AM
setting valves 351 windsor hydraulic lifters Doug Renton Engine 3 10-30-2002 02:22 PM
