Hydraulic Lifters - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2006, 07:22 AM
Hydraulic Lifters
I AM GOING TO PUT NEW HYDRAULIC LIFTERS IN BUT WHEN YOU BUY THEM THEY ARE COLLAPSED HOW DO YOU AJUST THEM WHEN YOU PUT THEM IN. THEY ARE FOR A 350 CHEVY 73.
Old 06-18-2006, 10:10 AM
MI2600's Avatar
Member# 3287
The lifters aren't collapsed. I just let them soak in a can of oil overnight and install them. It makes me feel better...don't know if it really does any good, but certainly nothing bad.
PS: ALL CAPS IS SHOUTING!
Old 06-19-2006, 05:50 AM
Last journal entry: PICTURE TEST
lifters
A few questions..
What are you working on??? chevy, john deere???
Why are you replacing just the lifters???
I personally never soak the lifters, they should be installed with lube on the face and engine oil on the out side diameter.... Then adjusted and the engine should then be primed with a drill to fill the lifters.
keith
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
hydraulic lifters Matts99Sierra Engine 6 03-05-2005 11:46 PM
How to tell hydraulic from solid lifters? frankenvette Engine 3 05-24-2004 06:20 PM
REBUILDING HYDRAULIC LIFTERS NAIRB Engine 103 05-22-2004 03:40 AM
Hydraulic Lifters Vista Cruiser Engine 8 02-19-2004 10:09 AM
