I'm going to be installing a new cam, timing set and lifters and I'm wondering what 'best practice' I should follow regarding the install of the lifters.
1. Should I soak the lifters in fresh oil for 24-hours prior to installing them?
2. Bearing in mind the lifters will NOT be pumped-up and will be empty of oil, do I still follow the normal pre-load procedure when setting lash (ie. zero lash + 1/2 turn)?
Thanks.
Thanks.
