Hydraulic roller lifters - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-13-2008, 09:07 PM
Customer support for the tards
I need some help regarding hyd roller lifters. My question is "once I set my valve lash, should the lifter loose its load"? In other words, when the valve is set correctly the I wait about five minutes, now my pushrod for the valve I just set and the rocker arm are now loose to the point where the pushrod will spin with my fingers and the rocker arm can be "jiggled" side to side. Can someone please help me clarifiy if I have a problem or is this normal?
Thanks in advance.
Old 09-13-2008, 09:11 PM
BOBCRMAN@aol.com's Avatar
Normal situation. As long as the lifter doesn't bleed down to where there is actual measurable lash.
Old 09-13-2008, 09:13 PM
Jmark's Avatar
Both Comp and Crane now suggest setting the preload with the lifters empty of oil. When the lifter is on the low side of the cam, 1/2 turn is about .020 thousands of compression on the lifter plunger. If, after sitting for 5 minutes, it gets looser, I suspect either the lifter is full of oil and then bleeding down a tad, or ??????
Mark
Old 09-14-2008, 12:55 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Yep, what they said. ^^
For a 7/16" rocker stud, a half-turn yields .030" preload. A 3/8" stud will need closer to 3/4 turn to yield .030.
.030 being the spec of my Comp hyd. lifter 885-16.
Hope this helps.
Old 09-14-2008, 09:20 AM
So if the lifter does bleed down to where there is "lash" present, does that mean the lifter is bad? These are used lifter/cam combonation that I purchased from a cousin of a friend so I'm not certain they are in good shape. Is it possible that there is a problem with the rocker arm? Some had clearance issues with the head studs and had to be filed down a small amount. Is that common?
Thanks,
Old 09-14-2008, 09:27 AM
Jmark's Avatar
Clearencing rockers is common in some applications.
Lifters that are bleeding down is not really a good sign, but not a deal killer either, depending on what you are going to do with the engine/car. For a budget driver, it may be ok.
Old 09-14-2008, 11:10 AM
Not a daily driver, trying to make a streetable bracket car. When I say streetable I mean something I can drive to the track only 15 miles away. Thanks for the help.
Hyd. Roller lifters on Solid roller cam danrace1 Engine 6 01-28-2010 06:21 PM
New roller lifters filled with mineral spirits? ssmonty Engine 1 05-31-2008 08:29 AM
Hyd. Roller lifters problems hotrodf1 Engine 121 10-25-2007 02:31 PM
roller lifters???? chevyelc81 Engine 5 06-18-2002 07:05 PM
engine rayjo Engine 3 04-28-2002 09:22 AM
