hydraulic roller lifters - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2002, 11:12 AM
Post hydraulic roller lifters
Installed a compcams retro roller cam & lifters in a sbc. Ran a short time & tore engine down. Bored,more compression. Problem is lifters, stored well protected,washed & blowed dried. Upon installing cannot set pre-load. Lifter acts like it is pumped up or a solid witch they are not.Soaked overnight in slovent and dried again.
Still cannot get plunger(?) to move off seat to get proper pre-load. Any ideas or sugestions will be appreciated. One last note I really don't want to throw these away! I am not that familiar with this type of lifter problem. Thanks
Old 09-01-2002, 11:53 AM
4 Jaw Chuck's Avatar
Post
Leave them upside down for a couple of days, then using an old pushrod and a piece of wood give them a rap with a soft face hammer while they are upside down. I put the old pushrod in a vise. Be very careful you don't damage the roller bearings, a little rap is all it should need once the oil has drained out. What has happend is the oil has thickened to the point of being as thick as STP, sometimes a little oven time at 200 degrees Farenheit helps too. Send the wife shopping while you do this.
— Han Solo
Old 09-01-2002, 01:23 PM
Post
4 Jaw has some excelient advise as usual. Check this out. <a href="http://64.90.9.168/cranecams/pdf/346e.pdf" target="_blank">http://64.90.9.168/cranecams/pdf/346e.pdf</a>
Just go to <a href="http://www.Cranecams.com" target="_blank">www.Cranecams.com</a> they have a lot of info you can look up.
I'll get right sooner or later.
[ September 01, 2002: Message edited by: hcheetwood ]
[ September 01, 2002: Message edited by: hcheetwood ]</p>
