>>>U say its a 388, ive got a 388,but it is a bow tie block with pontiac raised ports and there is no other cam to use but a roller.If it is street driven,then a hydraulic is in order mainly because at low rpms the rollers dont get enough oil,but ive heard that the new lifters are drilled to fix that so of course if its race only a solid is the only way to go.Please dont think im bragging or anything but mine makes 735 hp and is very dependable as far as both consistent and no maintenence at the track is concerend.
>>> If u need cam info I can give u a # to call if u want it.
Its Howads cams at 920-233 5228 . Ask for Robert, he runs it now that donnie Johansen sold it to competition products and is very knowledgable from t/f on down. I dont use anything else but their cams anymore and have never had a lobe failure or a prob with warranty or getting taken care of. Plus i know that they are alot cheaper than everyone else. mY last roller was 218 so its alot better than crane or comp cams.
>>>My specs are
>>>Bow tie block
>>>Eagle 4340 crank
>>>Eagle 3d rods with L-19 bolts
>>>Howards roller .675/620 286/292 @.050 112
>>>J&E >043/ 1/16/3/16 pistons 14.8 comp
>>>Pontiac raised port heads
>>>Jesel rockers 1.65 1.6
>>>titanium valves
>>>K Motion 1000h springs
>>>Jesel belt
>>>Dart intake 2 inch spacer
>>>9375 dominator
>>>MSD crank trigger
>>>Stefs pan
Am very pleased with the way it runs,and is alot lighter thanthe 555. It has run 8.10 in a 1500 lb altered at 4500 ft so it runs real gd.
>>>Thanks for letting me rant but maybe it will give you some ideas to kick around.
