Hydraulic or solid cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-19-2003, 06:50 PM
New Member
Post Hydraulic or solid cam
I'm building a 350 for my 89 camaro. It will be a weekend car drag racing during the summer. I've herd that hydraulic cams are easyer to degree in, but the solid cams seem to have a wider power range. What's the pro's and con's.
Old 01-19-2003, 07:22 PM
E.T. divided by $ spent= Speed
Post
Solid lifters are better for high rpm.But if your turnin 6500 or less use the Hydrualic so you don't have to adjust um every other day.Thats what I would do anyway.
As for degreeing,I've never done it,but I think you use solid lifters to degree a hyd cam anyway so it shouldn't make a differance.
Old 01-19-2003, 07:28 PM
Post
for a weekend racer I'd run the solid. they are more agressive and generaly make more power with the same specs as a hyd. you don't have to adjust valve lash but about twice a year. but run polly locks or roller rockers to make the adjustments easier.
Old 01-19-2003, 07:29 PM
Post
Old 01-19-2003, 07:31 PM
banned
Post
I am thinking of running solids in mine, To adjust I believe it is just tightening the rocker studs till they tick then a quarter turn or something past (don't adjust to that spec though cuz I dunno) But I mean for having to pull your valve cover occasionaly (good to see how your valve guides and springs are holding up) Solid does sound alot better
[ January 19, 2003: Message edited by: stonedchihuahua ]</p>
Old 01-19-2003, 07:34 PM
BOBCRMAN@aol.com's Avatar
Post
hey stoned, if you adjust solids that way you won't have to worry about making horepower, the engine won't run!!!!!!!!!
Old 01-19-2003, 07:39 PM
Post
Stoned thats hydrualic.1/2 turn past zero lash.Solids are set with a feeler gauge.
Old 01-19-2003, 07:52 PM
Post
get the cam lobe all the way down. your cam sheet should tell you the valve lash. generaly 0.025 to 0.030. put the proper size feeller guage betwen the rocker arm and the valve stem. take out the slack lock the nut and remove the guage.
