hydraulic throw out bearing - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2011, 04:19 PM
I have installed a Ram Hydraulic throw out bearing. I have a 3/4" master cylinder. I have checked all connections and no leaks. It will work for a little bit and then the petal won't come back all the way and no clutch. I have bled it a whole bunch but still have problems. Any ideas? SBC w/a Tremec 5 speed in a kit car.
Old 05-01-2011, 06:13 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
If not leaking---just for sport and amusement---jack up the back of the car very high and work the clutch master.
Might have a bubble in there.
I had a hell of a time bleeding the clutch in my 59.
Using an 87 slave with an 88 master.
Jacked up the back of the car---and bubbles came to the resevoir.
Been fine ever since
Old 05-01-2011, 09:01 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Perhaps your are over center the clutch pressure plate for some of those will go to .500 of movement which is .150 more than a pressure plate needs. You might try limiting the the pedal travel to something that doesn't over center the diaphragm.
Hydraulic throw out bearing bellhousing design? aztlanco Transmission - Rearend 8 01-14-2010 03:47 PM
throw-out bearing bkhaman Introduce Yourself 1 07-26-2007 08:23 AM
Throw Out Bearing JimKramer Transmission - Rearend 2 02-23-2006 08:56 PM
hydraulic throw-out bearing wally Transmission - Rearend 7 12-16-2004 02:00 PM
91 mustang throw out bearing jajeff22 Transmission - Rearend 9 02-20-2004 11:37 PM
